Ok, we need to move on. We replace shocks with new one from K-Sport, Brembo brakes are mounted, and we made custom exhaust that will be mounted next week. So, I am sharing some pictures from today customization.
CARS MEANING OF LIFE - AUDI TT project
Respect for the effort, looks good so far. 3 inch turboback, I guess? What cat will you use, 100 or 200cpi? Never heard of K-Sports btw, are they good and what do they cost?
We will not use cat at all
K-Sport is rely serious racing manufacturer of suspension, brake and brake discs, wheels etc. Price was around 1000euro.
Exhaust is fixed, now we need to make blends and polish all parts
We need to move on.
Still working on the car performance, but "small gift" arrived so I am sharing some pictures of it
Please check Recaro CS beauties.
P.S
Is there any1 who do not like them :D?
We need to move on. After internal discussion, we decide change old 310mm front discs with new 345mm discs.
... and we mount custom exhaust that we previously made.
Unfortunately, the project had to suffer due to uncoordinated terms and obstacles that we encountered, i.e. the high-pressure mechanical pump was the major problem, although it has already been replaced by a new one, which was reflected in the loss of power at high RPM.
We replaced the HPFP housing with the new Hitachi model (for the second time), and we also changed the internal HPFP AutoTech kit.
After that, we decided to change the pump in the tank, so we replace it with a pump from the Audi R8 model. Again we encountered a minor problem, i.e. original TT 2.0 TFSI pump had 16A supply and new one LPFP from the Audi R8 required a 40A source. The problem was solved when we received Torqbyte PM3 module. For now everything works fine, we are waiting for a new map, so we'll see after new remap where our borders are.
What we did on the engine, I'll mention again:
New K04 Turbo from the Audi TTS
Forge blow off
Forge cold intake
Forge catch can
S3 injectors
AutoTech HPFP
New Hitachi HPFP
New R8 LPFP LPFP
Torqbyte PM3 module for LPFP
A new fuel high-pressure sensor
A new fuel low-pressure sensor
New 6 bar fuel filter
New RS4 PRV
Wagnertuning TTRS inter cooler
All the pipes around the intercooler
Down pipe
The entire fi76mm exhaust systemIn the meantime we also replace old seats with new Recaro CS seats, also we replaced whole interior (carpets, sky, panels, etc.).
Love the Recaros
Nice car :dafür
Thank you mate, I appreciate your support.
Great pictures, nice work!
Thanks for sharing!
Thank you mate. I hope next week I will have more updates.
Finlay
I will share some photos of the car, before new Methanol kit arrive I hope you will like it
- Offizieller Beitrag
ich kann mir nicht helfen, aber dein tt sieht irgendwie höher gelegt aus :erstaunt:
Thank you even I do not understand last word
Alex thinks your car is to high. :hmw
Alex das sollte die normale höhe sein vllt weng tiefer. -
Fortunately, not every car needs this shabby Lake Wörthersee axle break look.
Level is ok........but the Rim Color
Hi there,
It's really nice watching the progress on your project.
Was the car on a Dyno-run already after all the changes were made?
What I don't like from the look like, is the weldseam on the airpipe from the filter,
looks not so nice done. But well... It's cosmetics, more important is the functioning.Are you going for the RS rear Spoiler as well? As you did almost all the RS look, it looks like that there's something missing now.
I don't know about your road conditons, but it would definitely look more nice if you would lower it a bit more.
Alex das sollte die normale höhe sein vllt weng tiefer.hahahaha I tough this was translation
Hi there,
Yes, it was on dino, we are stuck at 330HP, but new files including Water methanol will be finished in next two or three weeks.
